Crank but no start
225,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MIKWIL1023
At first when I turned key truck wouldn't make a sound.I replaced the starter relay. it then turned over but wouldn't start. prior to starter relay truck started fine.
Jan 26, 2020 at 5:46 PM
  • 55,743 POSTS
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? How does the engine sound when it is cranking over? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
This guide can help as well:
Sep 2, 2020 at 10:39 AM
