Crank but no start
108,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JUSTIN STUDDARD
  • 49 POSTS
I realigned my TRS and changed my fuel filter the other night and now my truck just cranks but it won't start. Prior to this I had no fuel delivery problems, no hard starts intermittent, no stalling or anything. I hadn't an issue with my TRS being out of line and while I was down there, I changed my fuel filter. Last night I took the battery out to go get it charged and while that was up, I pulled the fuel pump relay and the PCM and hit the inertia reset button. The battery was out for a little over an hour and as well as the relays I put the battery in primed it turned it on and off and it started up, so I drove her around for about 10-15 minutes. Shut her off went out this morning same issue crank but no start.
May 6, 2022 at 4:40 AM
  • 55,820 POSTS
Can you hear the fuel pump hum in the tank when you turn the key on but not start the engine? If not, it sounds like the fuel pump has gone out, which sometimes happens when changing out the fuel filter. Here are instructions on how to change the fuel pump out in the diagrams below, also I have included two engine no start guides please go over them as well.
and
https://www.2carpros.com/articles/car-not-running-advanced
May 6, 2022 at 8:10 AM
JUSTIN STUDDARD
  • 49 POSTS
So i have a wb of 112, when looking up fuel pumps i only see 111, 117, an 125. Should i get the 111.4 or .6 or one of the other ones?
May 9, 2022 at 11:08 AM
  • 55,820 POSTS
Sorry I am not sure what you are talking about, can you please clarify?
May 9, 2022 at 12:17 PM
