Car sits more than it’s driven. Replaced fuel filter, fuel pump driver module, has plenty of fuel in tank. Runs when starting fluid is sprayed in air box tube, then shuts off.
Was running slightly rough when started a few times over the past few weeks, but then went away after about 5 -10 minutes or so.
My scanner shows the following codes.
PO 191 fuel rail pressure sensor A circuit/range performance.
As well as.
PO 191 fuel rail pressure sensor A circuit range performance (pending).
Thank you for your help.
As well as.
Jul 8, 2023 at 5:14 AM
