Cranks but no start
152,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TW2017
The car will crank but will not start. The lights work on vehicle and on dash. I tested the fuses all good, spark plugs look good. I changed fuel pump about a year ago.
Sep 14, 2018 at 2:27 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Is there a security light remaining on past ten seconds? If so, try a spare key or clean off that key where the pellet is and try again.
Listen if the fuel pump runs for two seconds when you first turn the key to run, before you turn the key to start. If it does not run, check the fuel pump fuse and if it is okay, try swapping in or a new fuel pump relay and listen again for the fuel pump or see if it starts now. If the check engine light is remaining on, you may want to retrieve those trouble codes and post them in here.
Sep 14, 2018 at 3:07 AM
RENEE L
  • 1,260 POSTS
Hello TW2017,
I am sending you a link that if you decide to conduct the scan yourself will be a great help to you. The link features an article with written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the code number(s) please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Sep 14, 2018 at 8:05 AM
