CRANK BUT NO START
180,000 MILES • 2.8L • 6 CYL • 2WD • MANUAL
MARINE1998.
i have put a brand new fuel pump in because the old one was not kicking on. i have check the fuel pump relay and i can feel it kick on . i checked number one to make sure i have spark and i do. also check the rubber fuel line and fuel i coming to motor . Need help. will not fire up.
all fuses on the side of driver side i put in what was missing.
Aug 2, 2016 at 5:07 AM
RIVERMIKERAT
  • 6,106 POSTS
Use a noid light/test light to see if the injectors are being pulsed. Use it to also check to make sure all four plugs are receiving fire. You also need to check the fuel pressure, not just for the presence of fuel.
Dec 20, 2016 at 4:03 AM
