Crank but does not start?
150,000 MILES • 2.0L • 4 CYL • AUTOMATIC
SANDY0812
On the dashboard it Say safe mode and crank but doesn't start.
Dec 5, 2023 at 10:09 AM
  • 110,251 POSTS
They have been known to set that message when there is an issue with the fuel pump module. I need you to try something and let me know the results.
First, see if it will start if you use starting fluid. If it does and then stalls, we have a fuel-related issue. If there is no change, I need you to check for spark at the spark plugs.
Here is a link that explains how:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Dec 5, 2023 at 10:54 AM
