Cranks but does not start
268,905 MILES • 1.4L • 4 CYL • 2WD • MANUAL
JAMESIE SLIMMERTS
Overhauled the BLM engine. Replaced the crank sensor, diagnosed still not starting after clearing all error codes.
What could be the problem for it not starting.
Nov 8, 2020 at 9:21 AM
  • 110,251 POSTS
The Polo isn't offered in the US, so my technical info is very limited. However, I'll try to help.
Are you getting spark and fuel to the engine? I noted that you replaced the crank sensor which is usually the cause of no ignition spark. Also, is there any chance of engine timing being off? Does the engine sound normal when cranking? Is it possible for you to record the engine cranking and uploading it for me to hear?
Tell me, if you use starting fluid, does the engine start for a couple of seconds and then stall?
Here is a link you may find of interest. Take a look through it to see if anything helps. Also, let me know if you can make the recording and upload it for me.
Nov 8, 2020 at 10:47 AM
