Where is the crank angle sensor located?
329,457 MILES • 4.0L • 6 CYL • 2WD • MANUAL
BONNIEBONS2021
Where is the crank angle sensor on my 1994 XG ford panel van?
Oct 8, 2023 at 5:48 PM
  • 55,721 POSTS
This sensor is near the front of the engine at harmonic balancer. This image can help you see what I am talking about. It looks like you need remove the sensor bolts to change it out.
https://youtu.be/XJZHQ8bnDNM?si=1-TCwgtpDgnJP9-N
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Oct 9, 2023 at 2:52 AM
