CRANCK EXESIVELY BERFORE STARTING
15,000 MILES • 4 CYL • FWD • MANUAL
HABIB ADAM
  • 16 POSTS
When the engine is warm or cold, when I crank the engine for the first time, it do not start. unless I crank the engine for about three times before it start. when it start, black smoke do not comes from the exhust . the Check Engine Light does not illuminateon the dash when I open the ignition light or I start the engine.
Mar 25, 2016 at 4:34 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent gauge
Mar 26, 2016 at 12:56 AM
HABIB ADAM
  • 16 POSTS
please, when I checked the fuel filter,I saw that it is plugged with dirt.so I have replace and the coolant tempreture sensor is not working when I test it resistance. But in GHANA here, I will not get the CTS to buy. Thank you.
Mar 26, 2016 at 8:46 AM
