Crackling noise at the engine when accelerating aggressively
184,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ROLDAJX3
  • 6 POSTS
When I press the gas pedal to the floor for an aggressive start I can hear at the engine like crackling or when you squeeze a bubble wrap like a popping sound. After the truck catches above 50 mph it goes away and runs silently. Thanks for your help,
George
Mar 19, 2019 at 2:14 AM
JOETECHPRO
  • 705 POSTS
Hey ROLDAJX3,
Is the check engine light on?
Does it accelerate okay, no lack of power/hesitation/surging?
Can you check for PCM codes and report back?
regards, Joe
Mar 19, 2019 at 5:50 AM
ROLDAJX3
  • 6 POSTS
Hello, the check engine light is not on, I scan for codes and no codes show up and the truck is running perfect good acceleration lots of power going up hills. Can the tires do that vibration and after some speed go away?
Mar 21, 2019 at 12:22 AM
JOETECHPRO
  • 705 POSTS
Hey ROLDAJX3,
I think a good place to start would be to check the condition of the universal joints on your rear driveshaft.
Please see the guide below:
https://www.2carpros.com/articles/how-u-joints-work
Hope that helps, keep us updated on your progress.
Regards, Joe
Mar 21, 2019 at 1:57 AM
