crack head
100,000 MILES • 2.5L • V8 • 4WD • AUTOMATIC
BOBBIEHART
I just had the oil pan dropped and it was full of sludge, had that cleaned. I am also losing antifreeze fluid. could that antifreeze be leaking and getting into the oil pan?
Mar 12, 2017 at 10:54 PM
HMAC300
  • 48,601 POSTS
yes it could be something else however. have it pressure checked for a blown head gasket or like a cracked head, which I kind of doubt but it happens. It would have had to been overheated quite a bit to do that. you can probably rent a pressure checker at auto parts and fill system prior to checking.
Mar 12, 2017 at 11:55 PM
