CPS wiring cut (under-hood)?
142,000 MILES • 2.0L • 4 CYL • AUTOMATIC
BEN948
Okay, I was working to change the crank sensor since just lately it cranks a little long before starting. It seems to have lost some pickup also. So, after pulling the sensor out I realized the wiring (all three) were cut clean. The problem with this is the cut is less than two inches from the larger wiring loom. Where can I access these same wires under the hood so to run new wires without standing on my head ? The spot is low and dark against the firewall.
Jan 30, 2024 at 6:22 AM
  • 110,248 POSTS
Are you looking for easier access? The harness is not easy to reach. I understand. However, I believe it is only accessible from under the vehicle. Are you able to lift the vehicle for access?
Jan 31, 2024 at 5:18 AM
