Starting issue
143,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
TERRI WHALEY
I have to hold pedal to floor and hold the starter over before it will start. When it finally does I get flood smoke. I know it's not good on the starter at all. But I have a coolant leak at the pump maybe it's got on the CPS?
Jan 15, 2021 at 5:04 AM
Good evening,
Once it starts does it run okay?
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
I would start with a compression test to be sure the engine timing is correct. You could have low compression.
https://www.2carpros.com/articles/the-reasons-for-low-compression
Flooding could come from an injector allowing too much fuel so I would also check the fuel pressure.
https://www.2carpros.com/articles/engine-black-smoke
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Jan 15, 2021 at 7:53 AM
