Hard starting and runs rough
212,234 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SHADOW2627
Car scanner said it was the crankshaft position sensor was bad. So I changed it with a new one and it is still giving the same problem. It has a hard time starting but when it starts it runs rough. I put the gas pedal and nothing. It just stays at ideal.
Sep 6, 2019 at 10:52 PM
Good morning,
Codes do identify failed parts, just systems that have a failure.
What is the code that was set?
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Sep 7, 2019 at 12:09 AM
SHADOW2627
P0335.
Sep 8, 2019 at 10:18 AM
Below are the possibilities for the 335. All these need to be checked.
This is more of a wiring issue than the sensor issue.
P0335
Descriptor
Crankshaft Position (Ckp) Lost
Crankshaft Position Sensor Circuit
Probable Causes
(K824) 5-Volt Supply Circuit Open
(K824) 5-Volt Supply Circuit Shorted to (K925) Return Circuit
(K824) 5-Volt Supply Circuit Shorted to Battery Negative
(K853) 5-Volt Supply Circuit Open
(K853) 5-Volt Supply Circuit Shorted to Battery Negative
(K853) 5-Volt Supply Circuit Shorted to Return Circuit
(K925) Return Circuit Open
5-Volt Supply Circuit Shorted to Ground
5-Volt Supply Circuit Shorted to Voltage
Additional DTCs
Camshaft Position (CMP) Sensor
Crankshaft Position (CKP) Sensor
Crankshaft Position (CKP) Sensor Signal Circuit Open
Crankshaft Position (CKP) Sensor Signal Circuit Shorted Ground
Crankshaft Position (CKP) Sensor Signal Circuit Shorted to Voltage
Crankshaft Position (CKP) Signal Circuit Open
Crankshaft Position (CKP) Signal Circuit Shorted to (K824) 5-Volt Supply Circuit
Crankshaft Position (CKP) Signal Circuit Shorted to (K853) 5-Volt Supply Circuit
Crankshaft Position (CKP) Signal Circuit Shorted to (K925) Return Circuit
Crankshaft Position (CKP) Signal Circuit Shorted to Ground
Crankshaft Position (CKP) Signal Circuit Shorted to Return Circuit
Crankshaft Position (CKP) Signal Circuit Shorted to the 5-Volt Supply Circuit
DTC P0337 Present
Engine Control Module (ECM)
Physical Damage
Powertrain Control Module (PCM)
Return Circuit Open
Sensor Ground Circuit Open
Visual Damage
Sep 8, 2019 at 11:00 PM
