Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Optra
Electrical
Fuse Panel
fuse box plug
2011 CHEVROLET OPTRA
745 MILES • 1.6L • 4 CYL • MANUAL
MANY 6574
MEMBER
1 POST
Need car listed above fuse box plug.
Oct 23, 2019 at 7:43 AM
STEVE W.
Experienced Mechanic
Welcome to 2CarPros. Do you mean you need the harness connector that plugs into the fuse panel or something else? If you need the connector it will likely be either a salvage yard or dealer only item as it's not a commonly replaced item.
Oct 25, 2019 at 8:56 AM
Add image or video
Ask a new question
Engine overheating
Engine has low power
