Codes P0011, P0016, P0089, P2138 and P228D, could this be a computer or timing chain issue?
79,505 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
DOUG BYERS
My car is set up for English or French only. I was driving and, on my dash, German came up then back to English. The next day I had a timing chain type noise and on my OBD tester came up with codes of P0011, P0016, P0089, P2138 and P228D. Would this be a timing chain or computer issue??
May 15, 2023 at 2:52 AM
  • 55,604 POSTS
The diagnostic trouble codes you mentioned indicate several potential issues with your vehicle. While it's difficult to provide a definitive diagnosis without further inspection, I can give you some insights into the possible causes associated with these codes:
P0011 and P0016: These codes are related to the camshaft position sensor
P0089: This code indicates a problem with the fuel pressure regulator.
P2138: This code relates to the throttle/pedal position sensor/switch.
P228D: This code is related to the fuel pressure regulator control performance.
May 15, 2023 at 8:05 AM
