Could the front wheel speed sensor cause car to run bad
168,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
KROME26
Stabletrak light, awd light, traction control lights all came on and car lost power and will hesitate and barely go over 20 mph. would a bad wheel sensor cause it to run like this? all symptoms happened at same time.
Sep 5, 2019 at 11:04 AM
94 TRANSAM
  • 680 POSTS
Hi and welcome to 2CarPros. !
I am currently working on a 2007 GMC Sierra with the exact same issue except it had 17 codes stored. I have replaced the parts for 2 of the codes and they come right back. But it started out with the trac light and wont go over 20 mph. In neutral you can push the pedal to the floor and the tachometer wont go over 3,000.
The other guys are welcome to weigh in here and I am afraid I don't have a solid answer for you yet but I know right now it is having ground issues and at this point I suspect a shorted battery or a bad computer but I am still working on it.
I will update as I learn more but you could at least test the battery and see if it has any issues.
Rich
Sep 6, 2019 at 6:23 PM
