Could it be a ecm problem
161,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
EJB205
  • 6 POSTS
Took out neutral safety switch to clean put back together started car went through all gears back up lights work, but car shows a check gearbox light and car seems to be in limp home mode.
Oct 6, 2016 at 3:27 AM
JIS001
  • 3,412 POSTS
Scan it for codes and post them on here so we can get an idea as to what is going on?
Oct 7, 2016 at 3:43 AM
EJB205
  • 6 POSTS
Sorry my stupidy acting up again I forgot to align my neutral safety switch took it out again put it in correctly and car fine in all gears gear light went out car runs fine. Thank you
Oct 7, 2016 at 8:48 AM
JIS001
  • 3,412 POSTS
It happens to the best of us. Thank you for posting the fix.
Oct 7, 2016 at 11:12 AM
