Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Land Rover
Discovery 2
Ignition
Coil
Could a bad ground cause an ignition coil to fail
2003 LAND ROVER DISCOVERY 2
130,000 MILES • 4.6L • V8 • AWD • AUTOMATIC
VKTR
MEMBER
1 POST
The coil was sparking to the body and there was not any bolts on the coil bracket for the ground. Could this cause the coil to fail?
Sep 19, 2017 at 10:11 AM
Experienced Mechanic
Yep, the coil can overload and heat up causing the coil to fail. Here is a video and some diagrams (Below) that will help you get the job done.
https://youtu.be/iDgXwKA-IIc
Here is a guide that can help you test the coil.
Please let us know what you find.
Cheers, Ken
Images (Click to enlarge)
Sep 20, 2017 at 6:13 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
