As you accelerate it will start to hesitate and jump in higher RPMs
120,000 MILES • 4 CYL • AUTOMATIC
TRAVIS503
As you accelerate it will start to hesitate and jump in higher rpm's almost like it wants to jump time or as if there is a fuel shortage. what could it be? the codes are throwing something to do with advanced timing.
Sep 16, 2016 at 5:32 PM
WRENCHTECH
  • 20,760 POSTS
We would need the exact code number to be able to help you.
Sep 16, 2016 at 10:06 PM
TRAVIS503
1381 I believe this because it was a advanced cam unfortunately I cleared the codes and I can't pull it up
Sep 19, 2016 at 4:07 PM
WRENCHTECH
  • 20,760 POSTS
If you can't pull it up again, it means the problem hasn't occurred again. You are having an issue with the variable cam timing sticking in the over advanced position. The first thing to look at is that you oil is clean and full as this operates on oil pressure. There is an electric solenoid that can be bad or stuck that is often the cause also. It's a big job to remove the solenoid so try changing the oil first. https://www.2carpros.com/images/external/87563357.gif
Sep 19, 2016 at 7:45 PM
