air conditioner issue
130,570 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LORRAINE KING
Wire on metal grinding noise when the air conditioner is on.
Jun 2, 2016 at 1:11 AM
HMAC300
  • 48,601 POSTS
have the clutch of the air conditioner checked it may be adjusted to close and a mechanic will need to check that. If it has to be adjusted there are shims to remove and replace. It might be a compressor problem as well.
Jun 2, 2016 at 2:29 AM
