Cost to replace an oxygen sensor?
131,810 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
JAMES HOWARD6
What is the cost to replace an oxygen sensor on the car listed above?
May 28, 2025 at 4:21 AM
  • 55,647 POSTS
Which one? There are four. Typically, the sensor will cost about $90.00 labor and the parts are below.
ACDelco Exact Fit Oxygen Sensor: $79.49
Let me know if you want to do the job yourself and I can provide instructions, also let me know what code you have so I can give you the correct location of the sensor.
May 29, 2025 at 4:37 AM
