Battery corrosion
42,000 MILES • 6 CYL • 4WD • AUTOMATIC
JPT392
Can a battery cable completely disintegrate in seven months from corrosion on the positive side. If no corrosion present, at inspection seven months prior.
Apr 17, 2019 at 12:52 PM
  • 110,248 POSTS
Welcome to 2CarPros.
It's unlikely. What exactly happened?
Apr 17, 2019 at 12:58 PM
JPT392
Car would not start, proceeded to jump, lifted plastic cover on positive cable on battery. post is completely covered with corrosion, Connection on wire harness 90% gone.Have extend warranty and scheduled maintenance plan with Ford. Car is four and a half years old. I have nine maintenance visits with paper work. Each states a 50 point inspection done,with battery/charging system inspected, checked as done. Dealer contends this corrosion happened in the last seven months, since last inspection,due to defective battery,and wire harness not covered on warranty.Cost $1,200.00. My contention is no battery inspection was ever done, and a cable will not disintegrate in 7 months. Dealer says charging system fine, I have taken battery to be tested, holds 12.6 volts, no bulging, no visible cracks or leaks,test window on battery shows green.I also have the wire harness.Before I take this to the next level, I am gathering opinions by professionals if a cable can disintegrate in seven months, or the dealer staff never inspected the battery.
Apr 18, 2019 at 7:25 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
Anything is possible, but I would say no, it would probably take a little longer to develop corrosion like that. The battery is fine, absolutely no worries there. The thing I would worry about would be the harness. You said you already have a harness, I would just put the new one on. Fairly simple. Just undo the negetive battery terminal when you do it. Just unplug and replug in new harness as you go. You can get a product called Cro Guard at any auto parts store for a couple of bucks. Spray this on both battery terminals and it will inhibete corrosion forming on the terminals. Please get back to us with what the outcome is.
Thaniks,
Alex
2CarPros
JPT392
My fault said i had cable, meant i had old cable. Want opinion on corrosion time, or dealer neglect
Apr 18, 2019 at 10:57 AM
