Check engine light on and code P1346
2001 TOYOTA COROLLA
184,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
RON HRMZ
  • 9 POSTS
I had same code about 10 months ago which kinda got fixed by replacing the camshaft position sensor but i used to see that code as pending and goes away but now it comes back after resetting the ECU couple times. I bought the car a year ago and since then i replaced spark plugs, remanufactured set of injectors, gas cap, PCV valve, O2 sensor (used from junkyard). All these parts replaced due to another code i had sometimes (P0171) high positive fuel trims. The trims got to around 10% after all that work done but now i have the P1346 keep coming back. The engine has some rattle and knock-ish noise with cold starts which diminishes after warming up. I use 10w30 full synthetic oil. Do you think the engine has a timing issue or is it the camshaft position sensor going bad again after 10 months only?
Thank you in advance!
Jul 10, 2021 at 3:47 PM
  • 110,244 POSTS
I looked through the freeze-frame info you provided. Everything looks okay. So, I have a feeling you are correct, timing.
If you at the attachments below, they show the diagnostics for the code. The primary step is inspecting timing.
Take a look through the diagnostics and let me know if you are comfortable performing them.
Take care and let me know.
Jul 10, 2021 at 4:04 PM
RON HRMZ
  • 9 POSTS
Thank you Joe for fast reply! Is there any easy way to find out about timing without taking parts off?
Thank you!
Jul 10, 2021 at 5:21 PM
STEVE W.
  • 15,348 POSTS
The common reason for that code on the 1.8 is a stretched timing chain. The code really means that the camshaft timing is out of sync with the crankshaft location. So the crankshaft might be at top dead center on number one cylinder and normally the camshaft might be 10 degrees before that (or similar) in this case the code sets because instead of the computer seeing the signal there it is showing up at 20 degrees when the crank is at TDC.
There is an easy way to tell without removing any parts but it isn't a test many places can or will bother to do. It involves using an oscilloscope connected to the cam and crank sensors and you look at the actual signal from each. Unfortunately most shops don't bother to use a scope and will instead tear the engine apart, then tell you, "yup the timing chain needs to be replaced for $XX".
For the DIYer the easiest way without a scope is to remove the valve cover and set the engine at the proper position and then look at the timing marks on the cam sprockets.
For that you remove the engine trim cover, then the ignition coils, then the PCV hoses, the bolts for the cover and then the cover. Next you rotate the engine so cylinder 1 is at TDC and the timing mark shows at zero degrees. Then you look at the two timing marks on the sprockets. They should be facing each other and setting level with the edge of the cylinder head. Although this sounds like a lot of work it only takes about 1/2 hour to do. I suspect you will find the timing marks off like the third image, instead of being in the position of the black dots they will be like the red dots or not visible below the lip of the cylinder head due to the chain stretch. At that point it becomes a choice, this engine is an interference design, if the chain and timing components are replaced now it should be okay until something else wears or fails. However if the chain wears more and then fails, you would likely be better off replacing the entire engine as it will damage the cylinder head and the timing cover at the least.
I'm sure Joe can guide you through the swap of the chain. I just wanted to let you know that it isn't a minor problem if ignored. Not saying you would but many people do, they will drive with the check engine light on for years, then complain when the engine expires "for no reason"..
Jul 11, 2021 at 6:06 AM
RON HRMZ
  • 9 POSTS
Thank you Steve for taking the time and write all this valuable info! I have suspected the timing issue and will try to get to check it but is there any chance that this issue can be caused by the oil flow in vvti path or OCV solenoid not working properly? I forget to add that the engine smokes little bit if i push the RPMs higher than 2,500 RPMs and that's why i switched to 10w30 full synthetic and i even added half quart of 20w50 last time. I'm just trying to remove the possibility of vvti oil flow issue from equation.
Thank you!
Jul 11, 2021 at 7:22 AM
STEVE W.
  • 15,348 POSTS
Normally if it is the VVT you wouldn't get just the correlation error. You would get an error that shows the timing as stuck in one mode or the other or a circuit code for the solenoid.
Oil burning is a pain but with that mileage it's not surprising given how they build engines these days. Have you tried doing a top cylinder cleaning to see if it might free up the rings a bit and slow the oil use?
Jul 11, 2021 at 8:45 AM
RON HRMZ
  • 9 POSTS
I asked about the oil flow in vvti cause i saw bunch of stuff on google suggesting oil issues and a sludge in engine can affect that. I just took the Camshaft sensor connector off and saw some oil inside the connector. Do you think this can cause it? There is some oil leak around the sensor where it bolted on head and not sure how oil got inside connector. As i mentioned before i replaced the sensor about 10 months ago for the same code which disparaged until three weeks ago after i did oil change.
Jul 11, 2021 at 9:13 AM
STEVE W.
  • 15,348 POSTS
Oil in the connector isn't a good thing, but it's doubtful that it is the problem. It could change the amplitude of the signal but it isn't going to alter the signal itself as that is a digital square wave that counts the raised tabs on the sprocket. Myself I would grab my scope and check it but not everyone has one on the shelf.
However it's not that bad of a job to pull the cover to verify the issue either. If it is a stretched chain it can fail at any point and then the chain causes a lot of damage.
As for it being the VVT, not likely to be that because of the way the system operates. If it was the VVT sticking the engine would run very poorly and you would have more than the single code. More likely the oil change is causing the VVT to operate better and now the PCM is seeing the same error it saw prior to the new sensor. As an aside, when you replaced it the first time did you also reset the memory so it learned the position and signal levels of the replacement sensor?
Jul 11, 2021 at 9:36 AM
RON HRMZ
  • 9 POSTS
I replaced the sensor 10 months ago and did already 4 oil changes (for cleaning purposes) and many resets since then. I'm trying to avoid removing valve cover as much as i can as one of the cover bolts got loose and found it is stripped luckily i could use a bolt with nut and solved but not sure about the rest. I will look into scope option and try to borrow tools. I lost my job going through the pandemic and trying to use this car for a while as i can't afford buying another car or do a major job. The engine idles at 600 RPMs with slight vibration and engine struggles little bit going uphill and fuel trims runs positive always in the range of 10% sometimes would go to 15%.
Jul 11, 2021 at 10:14 AM
STEVE W.
  • 15,348 POSTS
Okay, if it's running that way it's possible it's already out of time some. If you can find a scope to use you can look online for YouTube videos showing how to do the testing, look for scanner danner, new level auto and pine hollow auto diagnostics, all three show the process and describe what to look for in more detail than I can type. A scope would also show you if it was working because you could unplug the solenoid while watching the signal and see if it moves in relation to the crank signal.
Jul 11, 2021 at 11:27 AM
RON HRMZ
  • 9 POSTS
Hey Steve!
I managed to get the Code 1346 not come back after i have added a quart of marvel mystery oil to crankcase. I think the VVTI was sticking or something and had some gunk which the additive in MMO helped to dislodge. Anyway the car runs fine now and needs exhaust work. Thank you for taking the time to share your experience.
Regards,
Ron
Sep 15, 2021 at 8:04 AM
STEVE W.
  • 15,348 POSTS
Could be some sludge found it's way in or more likely a bit of varnish formed in the VVT actuator and the MMO freed it up. The only issue with that is, it may cause other build up to move as well. I would probably change the oil again just to remove it. Exhaust work is always fun, especially in my area where the salt eats everything.
Good to hear it now is running good. Thank you for using 2 CarPros.
Sep 15, 2021 at 8:10 AM
