Cooling system
180,000 MILES
JOSE CASTILLO
Keep adding coolant but it's not leaking
Mar 30, 2016 at 12:36 PM
CARADIODOC
  • 34,414 POSTS
Best suspect is a leaking cylinder head gasket. One way to verify that is by adding a small bottle of dark purple dye to the coolant, then check a day or two later with a black light. The dye will show up as a bright yellow stain that you can follow back to the source. Auto parts stores will have the dye, and those that rent or borrow tools should have a black light. If the head gasket is leaking, you'll find the dye inside the tail pipe.
Mar 30, 2016 at 12:51 PM
