Cooling system leaking?
182,538 MILES • 2.2L • 4 CYL • AUTOMATIC
CHRISTOPHER IVAN ROEDER
  • 156 POSTS
Every time I stop the car if the engine warms up enough when I turn it off it leaks coolant instantaneously from somewhere but not the radiator. I am thinking it might be a heater hose or in the vicinity.
Dec 7, 2018 at 9:56 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It sounds like you should perform a cooling system pressure test. You will be using a pump to pressurize the cooling system with the engine off. You can then see where the car is leaking.
https://www.2carpros.com/articles/car-is-leaking-coolant
If you do not have access to a tester most auto parts stores have a tool loaner program and will rent you one. I have attached a tutorial showing what is involved. Hope this helps and thanks for using 2CarPros.
Danny-
Dec 7, 2018 at 12:41 PM
