cooling system flush
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DAN5594
is it okay to flush cooling system with white vinegar?
Sep 9, 2020 at 7:08 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I would just use a cooling system flush and cleaner like the Prestone brand. I've attached a picture below and it's available at Walmart for $4.00 Hope this helps and let me know if you have any further questions about this or tips on how to flush the system.Hope this helps and thanks for using 2CarPros.
May 7, 2021 at 4:09 AM
AL514
  • 5,696 POSTS
Hello, no I would not do that. Just drain the system and replace the coolant with the recommended type of coolant. Make sure you mix the coolant with 50% water. Or you can buy premixed coolant.
DAN5594
my question was not answered.
