Cooling system
132,000 MILES • V6 • 2WD • AUTOMATIC
CBERRY017
Something leaked from under the car, when I checked coolant there was very little in overflow so I added more. Could not get the cap off of the radiator to check level in there. Level in overflow had not gone down, but the cap on radiator is cool right after driving. Could this be that the water pump is not circulating? Haven't seen any more leaks. Not overheated yet, but I have the heater on. When I turn the heater off the heat gauge does go up. Haven't let it get past the halfway mark before turning heater back on.
Mar 3, 2016 at 8:27 AM
HMAC300
  • 48,601 POSTS
Keep checking the coolant tank to see if it's low again, then have the system pressure checked. It may be a head gasket or a bad freeze plug.
Mar 3, 2016 at 8:28 AM
CBERRY017
Thanks
Mar 3, 2016 at 12:43 PM
CBERRY017
Would it continue to leak if it's the gaskets or a freeze plug?
Mar 3, 2016 at 11:51 PM
HMAC300
  • 48,601 POSTS
You betcha, slower with a head gasket. If it were a bad freeze plug it would leak much faster.
Mar 4, 2016 at 12:19 AM
CBERRY017
It hasn't leaked since that one time and radiator is still cool after driving a fair distance
Mar 4, 2016 at 12:29 AM
HMAC300
  • 48,601 POSTS
then watch the coolant level and if it goes down have it pressure checked for leaks.
Mar 4, 2016 at 1:29 AM
