The air conditioner keeps running down the battery?
125,000 MILES
PAM SALLEE
Cooling system.
Jul 26, 2023 at 12:27 AM
  • 110,248 POSTS
If the A/C is causing the battery to discharge, we may have a weak alternator that can't keep up with the load. Is that what you mean or is it something different? For example, the A/C indicator light stays on when the key is off.
Let me know. Also, I need you to check the alternator output. It is really easy to do and only requires a basic multimeter or voltmeter.
Here is a link that explains how it's done:
Let me know what you find. Note: When testing, turn the A/C on to see what the battery voltage reads.
Jul 26, 2023 at 2:47 PM
