Cooling system
300,000 MILES • 2.2L • AWD • AUTOMATIC
ROCKIE WIMER
My car is leaking coolant when it is not running. I found the leak and there is a crack in the plastic piece that the lower radiator hose is connected to. I just replaced the radiator and the hoses. What is that plastic piece called? how do I fix it? And why does it only leak when the engine is turned off?
Jul 17, 2017 at 6:02 PM
  • 31,937 POSTS
it will be the thermostat housing. the leak will be there all the time under pressure, when the engine shuts down, heat sink can raise the system pressure a little and you may notice the leak more at that time.
Jul 17, 2017 at 10:30 PM
