Cooling system
2005 GMC YUKON
230,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
MARK41270
How to bleed the cooling system without a bleeding valve?
Sep 10, 2016 at 10:04 AM
SATURNTECH9
  • 30,869 POSTS
I just did a water pump on a 2005 Chevrolet truck with that same engine. Just filled the coolant and let it warm and topped it off. What problem are you having? I have not seen those have air pocket issues. I did a radiator on that same year Yukon and no problems with air in the cooling system.
Sep 10, 2016 at 1:50 PM
RYAN L
  • 272 POSTS
Do you meant engine coolant or air conditioning refrigerant?
Sep 12, 2016 at 6:19 AM
