Cooling system
1,700,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
MAN MOBBLYFE BRISCO
Are the fans supposed to turn on automatically when the car is started? Why does the car run hot when the A/C or heat isn’t on?
Jun 7, 2019 at 4:04 AM
Good afternoon,
The fan should come on when the engine reaches a certain temperature.
The fans should also come on when the A/C is turned on as well.
I attached a wiring diagram for you. Check the two fuses I circled for power on both sides.
Jun 7, 2019 at 6:32 AM
