Cooling system
100,500 MILES • 5.7L • V8 • RWD • AUTOMATIC
MITCHELL BAIRD
I had replaced my radiator and my thermostat because my engine was overheating. It is still overheating. I checked for leaks. Made sure everything was connected properly and tight. Is there anything else that could be causing my engine to overheat?
May 7, 2017 at 10:44 AM
CARADIODOC
  • 34,415 POSTS
First be sure the radiator fan is turning on. If it is not, the engine will not over heat at highway speeds when natural air flow is sufficient. Next, have your mechanic perform a chemical test at the radiator for a leaking cylinder head gasket. That just takes a few minutes. Usually if a head gasket is leaking, you'll be losing coolant too over time.
May 7, 2017 at 10:48 AM
