Cooling system
CLAUDEROBERTSON
  • 2002 FORD RANGER
  • 2.3L
  • 4 CYL
  • 148,000 MILES
Temperature gauge wasn't working-replaced thermostat with housing, dropped transmission and replaced metal tube through firewall. Heater works good, but has smell of leakage but find no spill or leak. Drove a distance and check gauge light went on and the temperature gauge was up, between normal and hot.
Friday, December 28th, 2018 AT 1:19 PM
  • 52,797 POSTS
Good afternoon,
Did you do a pressure test for the leak?
https://www.2carpros.com/articles/radiator-pressure-test
What tube through the firewall? I do not know of any pipe that the transmission needs to be dropped to install.
Friday, December 28th, 2018 AT 1:41 PM
CLAUDEROBERTSON
My mechanic did a pressure test. There was a metal tube with rubber on both sides that he replaced that was behind. It had pin holes in it. He said he had to drop the transmission to get to it. I just drove it for thirty minutes with heater works on high and nothing happened-no overheat gauge or red light. It still smells.
Friday, December 28th, 2018 AT 2:13 PM
  • 52,797 POSTS
Okay, if it smells it is leaking somewhere.
I would put some leak dye in the system. It will turn the coolant very bright green. If it is leaking, you will see it.
Friday, December 28th, 2018 AT 2:20 PM
  • 52,797 POSTS
Yep, go to the parts store and get the small tube of coolant dye. Just add it to the coolant and drive it.
Friday, December 28th, 2018 AT 2:23 PM
