Cooling system, check engine light on
137,000 MILES • 2.4L • 4 CYL
MICHAEL REED2
My check engine light went on and temperature gauge stopped working. I had the radiator flushed and replaced the thermostat. The temperature gauge works now but the check engine light is still on. Help!
Nov 4, 2018 at 1:26 AM
  • 55,721 POSTS
It sounds like the engine temperature sensor has gone out but to be sure lets run the codes.
Here is the engine coolant temperature sensor location in case you get a code for the sensor.
Check out the diagrams (below). Please let us know what you find. Cheers, Ken
Nov 5, 2018 at 7:02 AM
MICHAEL REED2
Thanks Ken,
Oddly enough I woke up this morning and the light was off. Roughly 24 hours. I am not going to fix what is not broke! lol, Thank you for your prompt reply and I will check into the sensor if it comes back on.
Nov 5, 2018 at 7:28 AM
  • 55,721 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Nov 6, 2018 at 1:43 AM
