Engine running hot
183,000 MILES • 3.6L • 6 CYL • AUTOMATIC
CATHYWEST4209
Replaced radiator, water pump, thermostat, still getting hot. What is left to fix?
Mar 18, 2020 at 6:11 AM
Good afternoon.
I would have a leak down test done to check for a failed head gasket. If compression is leaking into the cooling system, it will run hot.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Did you have this test done?
Mar 18, 2020 at 6:22 AM
CATHYWEST4209
I don't hear pressure when I removed the resivour cap is that a problem? And why don't I?
Mar 18, 2020 at 6:32 AM
That could be either from a bad radiator cap or you have a leak, such as the head gasket.
You need to have a leak down test done to see if it has a failed gasket.
Mar 18, 2020 at 6:35 AM
Just to add to this, are the cooling fans coming on?
I attached some testing which includes the things you replaced but also a few other things that we need to check.
As the engine begins to get to 210 degrees F the fans should be on high, if not then that is the issue. Let us know what you find with all this info. Thanks
Mar 18, 2020 at 6:39 AM
