Overheats and blows out the overflow on the reservoir
147,777 MILES
BILLY TURNBULL
Okay, I replaced the water pump and thermostat. It still overheats and blows out the overflow on the reservoir and it looks like exhaust or something like it is coming from the radiator reservoir as well. I don't know why.
Oct 13, 2019 at 7:49 AM
Good evening,
Sounds like you have a blown head gasket from the overheating.
You need to have a leak down test done to perform. That is when they remove the spark plugs and insert shop air into each cylinder one at a time and look for movement in the cooling system.
Oct 13, 2019 at 8:30 AM
BILLY TURNBULL
Okay, thank you.
Oct 14, 2019 at 4:35 AM
You are welcome.
Always glad to help.
Oct 14, 2019 at 4:42 AM
BILLY TURNBULL
Okay, I'm going to replace the head gaskets on my 1996 3.5 24 valve 6 cylinder . any advice is greatly needed.
Oct 16, 2019 at 6:26 AM
Okay, do you have engine repair experience? This is a very involved repair.
The heads will have to be sent to a machine shop and pressure tested as well as check to see if they are warped.
You will need a headset with new head bolts.
You will need a timing belt kit, complete with the water pump.
Is this something you can handle?
Oct 16, 2019 at 6:34 AM
