Drivers' side A/C and vents are not working properly
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARCUS MONK
The driver side A/C vents are not putting out as cold or forceful air as the two vents on the passenger side.
Jun 12, 2022 at 2:42 AM
SQM
  • 6,383 POSTS
This could be due to a faulty blend door actuator for the driver side.
The blend door actuator controls the hot/cold mix of air. Over time it can fail in a certain position and prevent the proper air flow.
The blend door actuator is located on the HVAC box behind the dash.
Here is a helpful guide:
I have attached a diagram below for your reference.
Let me know of any questions.
Jun 12, 2022 at 6:39 AM
