Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Equinox
Engine
Symptoms
Overheat
coolant temperature goes up and down at slower speeds?
2015 CHEVROLET EQUINOX
80,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BRYAN MARTIN
MEMBER
1 POST
coolant temperature goes up and down at slower speeds and the coolant fan is always running when i shut the engine down.
Feb 24, 2018 at 9:39 PM
Experienced Mechanic
Here is a guide to help you see what's going on with additional related guides:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
1. Low coolant level. You need to pressure test the system to verify no leaks.
https://www.2carpros.com/articles/radiator-pressure-test
2. Thermostat. Common problem s it sticks.
3. Clogged radiator. I would flush the system.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Images (Click to enlarge)
Apr 20, 2021 at 6:06 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
