air conditioner not cooling
150,000 MILES • 0.6L • 4 CYL • 2WD • MANUAL
NISHANTHA JAYASINGHA
Air conditioner is not cooling. gas full.suction pressure is 50 psi, discharge pressure is 225psi.
Jul 24, 2016 at 10:13 PM
HMAC300
  • 48,601 POSTS
50 psi is a little high so have a professional check this it may be a compressor or a problem with orifice tube. It may also be an actuator so pull HVAC fuse inside car for sixty seconds with key on then reinstall that will reset them. It may be the temperature actuator as well.
Jul 25, 2016 at 12:01 AM
