Only when driving up hill the engine temperature goes up
188,613 MILES • V6 • 4WD
JESSE_COPLIN
The car runs cool until I am driving up hill. At that point, going uphill, the temperature rises to the 3/4 mark and stays. Once I return to flat ground it cools down. I burped the unit and it seems to be holding, but I am confident it will return as I am not a mechanic and do not know the bottom line. Please help!
May 5, 2020 at 1:14 AM
  • 110,251 POSTS
If this only happens when you are placing the engine under a load, then I suspect it is likely in need of flushing the cooling system. I feel if it was the thermostat or another problem, it would also happen when driving on a flat surface.
I would start by flushing the system to see if that takes care of the problem. Here is a link that explains how it's done:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Let me know if that helps. Also, let me know if you have other questions or need help.
May 5, 2020 at 2:05 AM
JESSE_COPLIN
I am researching doing this on my vehicle now. I hope it works. Thank you!
May 5, 2020 at 2:19 AM
  • 110,251 POSTS
You are very welcome. If you have a chance, let me know the outcome. Also, if you need help or have questions, let me know.
May 5, 2020 at 2:10 PM
JESSE_COPLIN
So the erratic needle on the temperature gauge stopped moving all together and is sitting on cold at the bottom. I think it may be a sensor. But the 2007 Sorento has so little info online. Could it be a faulty sensor?
May 5, 2020 at 2:17 PM
  • 110,251 POSTS
Yes, the engine coolant temperature sensor (ECT) can be bad or the connection could be loose or corroded. The ECT is mounted on the cylinder head. I attached a picture to help you locate it.
Let me know if this helps or if you have other questions. Note, before replacing the sensor, confirm there isn't a connection issue.
Take care and let me know if you have questions or need help.
May 5, 2020 at 2:29 PM
JESSE_COPLIN
Thank you so much. I will have a go at it tomorrow morning. I will update as I progress.
May 5, 2020 at 2:32 PM
  • 110,251 POSTS
You are very welcome. Let me know if I can help.
May 5, 2020 at 2:51 PM
