Cooling fans only come on with A/C and when temperture sensor is unplugged?
120,000 MILES
KAYDENEANES
I’m having same exact issue did you ever figure it out?
Jul 11, 2025 at 3:07 PM
  • 55,616 POSTS
Which post are you talking about do you have the URL? The PCM controls the cooling fans FYI, I would run the codes to see is nay are stored. This can tell use what's going on, you may have a bad PCM or is needs to be re-flashed. Also, I would check the main fan ground which is located at the right front body mount core support. Here is a guide to help you scan for codes.
Please go over this guide and get back to us.
Jul 12, 2025 at 4:29 AM
