Cooling fans not turning on?
160,000 MILES • 6 CYL
DROSE300
Cooling fans don’t turn on. They work when power is directly applied to the fan motors. And they work when the ac pressure sensor is unplugged. A/C compressor was replaced as well as the expansion valve condenser and A/C pressure sensor.
Sep 27, 2025 at 5:32 AM
  • 55,628 POSTS
When you turn the A/C on and wait about 30 seconds does the cooling fans come on? Also does the A/C get cold? If the A/C is not working the fans will not come on until the engine is hot. Please let me know. Also do you have a check engine light on? IF so you should run the codes to see which ones are stored, here is a guide to help you:
Please go over this guide and get back to us.
Sep 29, 2025 at 3:30 AM
