cooling fans/no heat
155,000 MILES
BERTITO
i have no heat plus my cooling fans do not run in high mode so the temperature rises moore than 3/4 sometime it runs hot but does not overheat while am driving about 40mph the temp drops almost to normal not while im sitting in a red light can some one help well to mention i replace thermostat,cooling temp sensor and siwch both and check all the fuses and relays>?
Apr 12, 2013 at 8:08 AM
check the thermostat. if it is bad, then the fans will not work
Apr 12, 2013 at 8:09 AM
