Temperature gauge not working properly
112,677 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
MOUSE357
  • 58 POSTS
Could someone give me an idea why my gauge would be reading normal operating temperature, as soon as I start my car?
Even after it's not been started for several days.
Thank you for your time.
Dec 27, 2021 at 12:10 AM
  • 110,251 POSTS
When started cold, it should be all the way to the cold side. The normal operating temperature (after it's warmed up) should be around 200 degrees F.
Here is a link that explains how a coolant temperature sensor works. You may find it helpful:
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
Let me know what is happening so I can better help.
Dec 27, 2021 at 9:01 AM
MOUSE357
  • 58 POSTS
Yes but no sir. My car can sit for several days and as soon as it starts it's already reaching normal operating temperature...
How is that possible??? Ya in the center where it has been for over a year until just recently. It started going to the center automatically. It's below freezing outside and its already normal operating temperature... Don't understand it. Thank you for your time...
Dec 29, 2021 at 11:16 AM
  • 110,251 POSTS
Is the vehicle starting and running properly? If the gauge is that high when cold, either the coolant temperature sensor is bad or there is a short in the wiring.
Let me know if it is running properly.
Dec 29, 2021 at 11:22 AM
MOUSE357
  • 58 POSTS
No having a really rough time starting it at times.
Dec 30, 2021 at 6:16 AM
  • 110,251 POSTS
Okay, chances are there is an issue with the sensor. By any chance, do you have access to a live data scan tool that can communicate with this vehicle? I have a feeling the sensor is causing too lean of a fuel mixture to start the engine cold because it is indicating the engine temperature to be at operating temperature.
If you look below, I highlighted the sensor in the pic. It should be on the driver's side under the hood on the engine end. Check to make sure the connector is good, tight, and there is no corrosion.
Dec 30, 2021 at 8:30 AM
MOUSE357
  • 58 POSTS
No not live data. I've got an O.B.D. 2 DIGITAL INNOVA 3100c Code Reader. But off and on for over a year that I've owned the car it's leaked a little coolant every now and then.
Now could a messed-up thermostat cause this issue?? I've noticed that my temperature doesn't seem to be getting very warm here lately also.
Dec 30, 2021 at 11:01 AM
  • 110,251 POSTS
If the engine doesn't reach operating temperature, yes, the thermostat may be stuck open. That will reduce heat. Also, if the coolant is low, that too can cause it. Make sure it isn't low. Also, it is common for a leak to be at the coolant temperature sensor.
I attached the directions below for replacing the thermostat. However, here is a link that shows in general how it's done. You can use this to help guide you.
Now, the temperature sensor on these is a bit unique. If you follow the radiator hose to the driver's side of the engine compartment, you will see the sensor. (See pic 10 below) What makes it unique is the way it is mounted. There is a plastic clip shaped like a U that holds it in place. (See pic 11) That needs gently removed and then the sensor will pull out. Make sure to remove the old O-ring and lubricate the new one with coolant before you install it. I had to go online to find some pics. I attached them below. They are the last two pics.
Since you need to drain the coolant for either of these procedures, I would replace both at the same time.
Dec 30, 2021 at 1:11 PM
