cooling fans
169,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
TED FINLEY
  • 10 POSTS
cooling fans only come on with ac, just had new transmission installed , rear oil seal, intake gaskets replaced, $4100. and they can't fix fans I replaced the dual fans with new unit no better off this is what burned out other trans.
Apr 27, 2019 at 11:35 AM
  • 55,743 POSTS
It sounds like you have a relay out. to be sure here is a guide to help you test them and the cooling fan wiring diagrams below so you can see how the system works along with the relay locations:
Apr 29, 2019 at 5:40 AM
TED FINLEY
  • 10 POSTS
checking wed
Apr 30, 2019 at 11:45 AM
  • 55,743 POSTS
Nice, let me know I want to get this fixed for you.
May 1, 2019 at 4:50 AM
