Cooling fans not working properly?
175,502 MILES • 3.4L • V6 • 4WD • AUTOMATIC
RICKY JUVINALL
My fans are not working but if I disconnect the temperature sending unit they work just fine.
Nov 9, 2024 at 12:39 AM
  • 55,851 POSTS
Usually this will be a bad engine coolant temperature sensor. Here is the location and how to change it out so we can be on the same page. Check out the images (below). Please let us know what happens.
Nov 9, 2024 at 3:57 AM
RICKY JUVINALL
I put the new temperature sending unit in and it's still overheating, it did not fix the problem. Could you please let me know what may be going on? Thank you, have a nice day, bye.
Nov 13, 2024 at 11:02 AM
  • 55,851 POSTS
So, the engine overheats while the cooling fan are running? I have seen a stuck thermostat cause this issue. Here is a guide to go over to help understand what's going on and i have included how to change the thermostat out. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Nov 14, 2024 at 2:07 AM
RICKY JUVINALL
I'm sorry I put the temperature sending unit in and the fans are still not coming on. When I take the temperature sending unit plug off, they come on but when I put it back on, they don't stay on they quit running.
Nov 14, 2024 at 7:37 AM
  • 55,851 POSTS
You may have a PCM that is going out, to be sure let's use a scanner to see what the PCM is reading for the engine coolant temperature.
This guide can help:
Please go over this guide and get back to us.
Nov 15, 2024 at 1:38 AM
