Cooling fans
93,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
DA GOAT JMC
Car started to over year so I replaced the cooling assembly with a new one but fan only comes on when I use the A/C. I also replaced the three relays and still the same issue. The fans used to come on every 10-15 seconds now nothing not even when the motor warms up.
May 16, 2019 at 11:21 PM
JDL
  • 16,098 POSTS
Some makes and models, the fan will come on and run if you unplug the coolant temperature sensor. I'd take a look at that sensor. Any applicable trouble codes?
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
May 17, 2019 at 1:10 AM
