Cooling fan switch/climate control pressure switch location needed
168,056 MILES • 5.7L • V8 • 2WD • AUTOMATIC
WARDENAWARD
Hello, I am trying to locate the cooling fan switch or climate control pressure switch as I’m being told it’s properly named. My vehicle listed above is a Z28. I simply just need to know the exact location of this switch so that I can install my new one. thank you!
Mar 20, 2021 at 7:43 AM
It is located near the right shock tower.
I am attaching all the info below that will help locate this including the wiring diagram in the event you need this as well. Thanks
Mar 21, 2021 at 11:04 AM
