Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Vue
Engine Cooling
Cooling Fan
Temperature Sensor
cooling fan sensor
2004 SATURN VUE
150,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
SMANUELE
MEMBER
my cooling fan runs non-stop. do I need to replace the cooling fan sensor?
Jan 15, 2016 at 5:30 AM
PACO8224
Experienced Mechanic
Did you do any recent work on the cooling system, make sure your coolant topped off
Jan 15, 2016 at 5:53 AM
SMANUELE
MEMBER
Coolant is full, even in below freezing weather it runs as soon as I start the engine.
Jan 15, 2016 at 5:58 AM
PACO8224
Cooling fan sensor can cause the problem but I would check to see if you have any engine codes even pending codes first
Jan 15, 2016 at 6:03 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
